dougrainer
Jan 03, 2023Nomad
opnspaces wrote:
Many roofs are not glued down on the outer edges. If there are no obvious tears in the membrane and the membrane wraps over the edge I would not worry about it.
What makes you think this is factual? They ALWAYS run glue to the edge. The only time they do not install glue is ON the radius from the roof to the sidewall IF the RV has radius instead of a 90 degree edge. The reason they do not on a radius has to do with the radius does not absorb the glue like wood and will cause discoloration below the rubber. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
