My Carefree awing is loose on one end. What I mean by this is when it is rolled up you can pull it away from the wall around 3/4 inch. Only on one side. Any ideas on a fix? PJMAX:? Moved to Tech Iss...
Your awning has probably moved in the awning rail on the trailer. Unroll the awning, slide the awning in the rail on the trailer toward the awning arm that is not going in all the way approx. 1", then roll back up, what that does is center the awning on the roller to the rail. After it closes up properly, put a screw in each end of the awning rail to secure and hold in place...
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
