enblethen
Feb 19, 2014Nomad
What style of base does the lamps have?
The standard bayonet style socket can be bent slightly to tighten them up.
The wedge style is a little harder to do. You can bend the wires on the lamp outward slightly.
The grease will not help hold the lamps in place.
The grease will help continuity against corrosion. I use it on all my exterior lamps.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
