brianseay1 wrote:
Just got home last night from a trip. Parked the rig everything was fine.Left the fridge running and water heater was on.Went out this morning and the wife took out the rear slide to get stuff out and brought the slide back in. I go to put the rig in the garage and to plug it in and now I have power to the Inverter panel but nothing else. No lights but the microwave does come on. I have checked the breakers and fuses everything looks good. I have tried to reset the battery disconnect but get nothing. Entry lights do not come on. Steps are working. Fridge will not come on. what do I need to be looking for ??? I checked the batteries and they are fully charged. I am lost, any help is appreciated.
From the sound of it (and the fact that you have a class A) it seems that you likely have a pass-thru inverter charger with a sub panel downstream powering at least the microwave and stairs...Whats happening it seems is that even though you have shore power, the inverters ATS transfer switch may not be sensing shore power, so inverter is just powering up the circuits in the downstream sub panel only....Just saying
3 tons
