cavie
Oct 29, 2019Explorer
You need to tell use what system goes on and off 12 volts or 120 volts. The word POWER and EVERYTHING does not help us. You have 2 POWER systems. Are the touch lights 120 volt lamps? If so unplug and put aside until the problem is fixed to stop confusion. So far all I can determine is you have a loose connection somewhere. Without proper information I can't help you. If the Surge protector says it ok then remove it for testing purposes. If it is an EMS and you have a low voltage problem then it is turning off the 120 volt power until it comes back into the 108 to 132 volt range. The lights will explane this for you. Look at the directions for uses. As a Master Electrician I would love to help.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
