fpresto
Jul 23, 2016Explorer
As you mentioned the wires run through the axle and this is a common issue for intermittent issues with the brakes, not your issue in this case. The problem is that most axles are not finished on the inside and the wires can vibrate enough against the rough surface to develop bare spots. This is probable the first place to check if you are intermittently getting faults on the controller.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
