wa8yxm
Nov 20, 2018Explorer III
WesternHorizon wrote:
Chassis manual shows “Modified vehicle power feeds” 50A fuse in Power Distribution Box. Pulled this with difficulty: OK.above?
You ask what changed.. You pulled (with difficulty) the fuse and I assume put it back. in the process you scraped the contacts (Blades) clean and restored contat.. Alt-The fuse may be bad in a way that allows it to opperate intermederate (I do not have the time to explain that but a bad connection internally vibrates into an out of contact) I do not think this is common with BLADE type fuses (E LIke ATC) but it is with some others... More likely corrosion erased by pulling and inserting.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
