joebedford's avatar
joebedford
Nomad III
Dec 15, 2014
"Lost" the bottom string on my pleated day / night blind?
I have a large 6'+ wide day / night pleated blind in my living room slide.
I thought that one of the strings had broken but on closer examination I see that the plastic doo-hickey that attached the string to the wall at the bottom broke and allowed the string to disappear into the bottom horizontal frame.
I know I'll have to take the blind down and fold it up at least partially to get the stress off the strings. But then what? How do I get that string out of the bottom frame? Does it come apart somehow?
Appreciate your suggestions.
  • BFL13 wrote:
    The string would have been knotted on the do-hickey and that knot should have stopped it going into the hole in the end cap. So the string may have broken and now be too short. You can buy that kind of string and restring if needed. Huge PITA, but do-able.
    X2 that the string is likely too short to be able to get it back on the tension spool.
    Not all that hard to restring these shades. See these instructions.
  • The string would have been knotted on the do-hickey and that knot should have stopped it going into the hole in the end cap. So the string may have broken and now be too short. You can buy that kind of string and restring if needed. Huge PITA, but do-able.
  • Pull the end caps off the bottom metal piece and slide it off. You will probably see the string. pull some slack and run it through the hole in the end cap. Reassemble the pieces and you should be fixed.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
