Dutch_12078
Nov 04, 2017Explorer III
2oldman wrote:centerline wrote:Yes, but if you want your food heated in a MW it's going to work a lot better at 1200w @ 120v.
as for efficiency, from a power consumption standpoint, its more efficient running ANY 12vdc component directly from the batteries than it is running a 120vdc component thru an inverter.. the larger the power draw of the component thru the inverter, the inefficiency increases exponentially..
Or if you want your coffeemaker to finish making a pot the same day. ;)
