time2roll
Jan 24, 2014Nomad
What is the battery float voltage? s/b 13.2 to 13.5 volts. Lower in summer, higher in winter.
How full is the water level? s/b 1/4" to 1/8" below the split ring. If just touching the split ring is absolute max and may still push some acid out.
How old are the batteries? Older batteries gas more.
How are you cleaning the terminals? What are you using to protect the terminals from corrosion after reassembly?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
