dedmiston wrote:
McFalls2014 wrote:
dedmiston wrote:
Try cracking your gas cap and run it again. If it's not venting properly, maybe it's starving the gen for fuel.
Is it hot where you are? Maybe the tank is so full that its burping fuel out of that lower vent line as the fuel expands.
Its not hot, in the low 70s. Tried cracking the cap yesterday and it ran a little longer than normal but still shut down. What has me really confused is what is the line running from the top of the tank dripping fuel? If thats the vent line it should be venting with or without a vented cap I would think. Correct me if Im wrong as we are new to all of this. If it was clogged how would it drip fuel?
It's possible that it isn't clogged, but just poorly designed. Maybe it's too small to vent enough, but large enough to puke out some gas. Those actions also work in the opposite direction of each other, so maybe a spider web is allowing gas to drip out, but won't let air in?
What brand is your hauler and how long did it sit? And how many hours are on the gen? This will tell you how much the previous owner used it and whether he used it enough to service it or not.
Also, I just re-read your original post and now I'm not sure if I'm picturing your setup correctly or not. Do you have separate tanks for your gen and fuel station? Or do they share a tank?
Brand: We love our hauler, but the manufacturer didn't have much experience with toy haulers and a lot of the systems were designed poorly. Luckily our gen has never been a problem, but the fuel station doesn't vent well and it will suck itself inside out if I don't crack the gas cap before I pump fuel into our buggy. I only bring this up because there's a difference between "broke" and "designed by morons". You need to figure out which category you're in before you can fix it.
Sitting Around: If your hauler has been sitting around for a long time with gas in the tank(s), then that could explain the rough running. You don't know yet whether the gen is getting starved for fuel or if there's something else wrong with the gen. Maintaining the gen is pretty easy, so I would start by performing all the basics: change the oil & filter, plugs, air filter, and inspect the fuel filter (if it has one). Those fuel filters are known to be trouble and they're cheap enough to just replace it even if it isn't part of the problem.
Next I would deal with the fuel. It's not like a bike where you can just drain the tank into a 2 liter Coke bottle, but you can siphon the old gas into a couple of jugs while you troubleshoot this. I would siphon out as much of the old gas as possible, pour in a bottle of Seafoam and new gas, run it long enough to let the Seafoam get into the carb, and then let it sit for a day or more to let the Seafoam do its thing and then test it again. With fresh fuel, new oil & filter, new plugs, new fuel filter, and new air filter, it will hopefully be happy again and run like normal.
If it sat for too long without being exercised by the previous owner, then there's a good chance the carb is varnished. People will tell you that they service their own carbs, and Onan will tell you they can't be serviced. Who knows. They aren't very expensive to replace though.
About the pumping station...
There's a notorious problem with the gears in the pump handle. I can't say if this is your problem or not, but post in the Toy Hauler Forum here and we can work with you on that. Basically, there's a plastic gear in the pump that swells up. I think it's about the diameter of a quarter and the thickness of two or three quarters. When it dries out (like after sitting unused for a long period of time), it swells up in thickness. The fix for this is to either replace the gear or remove it and sand it down 1MM at a time until it works.
The gear problem is a weird one and it's been an issue for more than 15 years that I can remember. The weirdness is that some people have the issue and it's like herpes and never goes away. Those people have to keep a baggie of spare gears and replace them every year or so when they go bad. I didn't use the fuel station on my last hauler much and didn't mind when it stopped working. I use the pump all the time on our current hauler and it's never given me any trouble (except that I have to crack the gas cap every time I use it).
Sorry that none of this is any kind of magic bullet answer, but I bet we'll get you fixed up.
And either way, drop by the Toy Hauler forum and introduce yourself. Add your hauler info (and the toys, if you feel like it) into your profile so folks will know your setup better.
Take care.
Thanks, I updated my profile with more info. Im not much worried about the pumpstation at this time but would like to figure our the generator and pressure issue. We have dont all the above on the generator and have added Seafoam and fresh fuel. We actually mixed some Seafoam and fuel in a jug and let the gen pump straight from it and it ran forever so Im confident the problem is fuel related. I purchased a vented fuel cap today on my lunch break and am interested to see if it makes a difference. The hose out of the top of the tank is still a mystery.
