NinerBikes
May 10, 2015Explorer
Set at 14.5V for starters, and see if you get to 15.0V at the battery terminals when close to fully charged, you might only get 14.8V. Depends on length of run from charge controller to battery terminals, gauge of wires, connectors if any, etc. Some setups create voltage loss, others are so good that you see .3 to .5V gain from that showed. Use a good Digital Multi Meter on the battery terminals to confirm. Amperage charging rate will tell you bit also, with practice.
If you are leaving this attached to the batteries to float charge daily, drop your V down to 13.2 to 13.5 indicated or so. Set the V higher when you are out camping daily, 14.2 to 14.5V for daily recharging.
You could probably "tune" the voltage loss to that actually displayed by running something like 14 gauge or 16 gauge wire, to induce a little more loss from the controller to the battery bank. In doing so, however, you'll lose the ability to almost equalize charge the battery.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
