scrubjaysnest
May 11, 2015Explorer
SkiSmuggs wrote:
Okay, the battery was fully charged, connected to shore power, showing 13.7 on the controller, didn't check my voltage display and, at the time of the picture it was cloudy. I have disconnected shore power and am letting it sit for now as it is getting dark. I understand that it takes full sun at 90 degrees to panels to produce 10-11 amps (5.89 each). This isn't the Renogy kit but purchased separately over time with the Solar30 controller. I initially saw .3 with one panel connected and .6 amps with two, and that fell off to .3 with clouds. Is it possible to show panel amps that low with a fully charged battery? If so, maybe there is no problem.
Panel tilt needs to be ~ your latitude, not 90 degrees for max output.
Flat on the roof won't get max.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
