BFL13
May 11, 2015Explorer II
scrubjaysnest wrote:SkiSmuggs wrote:
Okay, the battery was fully charged, connected to shore power, showing 13.7 on the controller, didn't check my voltage display and, at the time of the picture it was cloudy. I have disconnected shore power and am letting it sit for now as it is getting dark. I understand that it takes full sun at 90 degrees to panels to produce 10-11 amps (5.89 each). This isn't the Renogy kit but purchased separately over time with the Solar30 controller. I initially saw .3 with one panel connected and .6 amps with two, and that fell off to .3 with clouds. Is it possible to show panel amps that low with a fully charged battery? If so, maybe there is no problem.
Panel tilt needs to be ~ your latitude, not 90 degrees for max output.
Flat on the roof won't get max.
He did say that correctly. The panel does best with the sun right on it.
Panel tilt to get that at high noon is seldom the same as your latitude. Just twice a year on 21 March and 21 September.
For the curious only---
Panel tilt is the same as the zenith distance (90- sun's altitude) at high noon. For example, at 49N with Declination at 23 degrees on 21 June, Altitude 64 degrees,
ZD plus Dec = Lat and 90-64 =26 for ZD and 26 + 23 = 49
Your tilt on 21 June at 49N is 26 (same as ZD) to get the sun 90 degrees to the panel. When Dec is zero on 21 Mar and 21 Sep, that is when your tilt = your latitude.
Optimum tilt for the day is less than the tilt for noon so you can get more sun earlier and later. So once you know your best tilt for noon, lower the South facing panel by say 10 degrees and leave it there all day.
If you are twirling a tilted panel it is the opposite. Early and later in the day you want it tilted higher than at noon for best results.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
