SkiSmuggs
May 11, 2015Explorer
NinerBikes wrote:SkiSmuggs wrote:pianotuna wrote:
Hi,
Put a nice heavy load on the battery bank when the panels are in the sun.
What did you choose for voltage set points?
I left the "ceases charging" parameter at 13.8 for now. I see where a couple of folks change theirs depending on circumstances which sounds like a little of a pain to remember. My panels are always there whether I am on shore power or not so I am open to suggestions.
Try 14.5V camping, 13.2V storage.
Write it down on paper, a small piece, then put some clear packing tape over the paper, on the solar charge controller, to seal it in place. Couldn't be easier to remember.
You don't get all the luxuries of home in an RV without a little bit of daily maintenance and routine. This is not plug and play, so get used to it, now.
Good, makes sense, thanks. I will write it on my wife's forehead as I will see it more readily. ;)
So my RV converter will do bulk charging at home or hook up campsite, and change the Solar30 to do that while dry camping. I guess I can handle this.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
