It is immediately suspicious of 2 FUSES (I think you mean breakers, but we work past that for now), because your TTs 30amp feed should only be 1 (One) 30amp breaker.
It sounds like you are not tuned to electrics, but you had best find someone that is right now. I am going to suggest that you find out what is going on.
If your electrician made the common (way too common) mistake, it could have already done a great deal of damage to anything connected. Many electricians, it seems, never read either the receptacle itself or the code about a TT30. The TT30 (two slanted blades and a round ground pin is a antique standard that got grandfather in and is still in use though it meets none of the modern standards. Many electricians assume that because the two blades are the same, it is a 230V connection. (Like a clothes dryer might be.)
Good luck, I hope I am wrong about the damage.
Matt
