Grit_dog
Jun 02, 2022Trailblazer
Depends. Look at the flow when you drain it. This is literally not a question we can answer. I've had campers trickle drain and others that run good.
But regardless, you have no pressure, so you won't get even close to adequate flow to feed your pressure washer. As in NO pressure.
Have to hook to the pressure side.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
