dougrainer
Jun 02, 2022Nomad
The valves have about half the size of your Pex lines. I doubt you could get enough volume thru one of those valves for a pressure washer. Are you planning on using the RV water pump and fresh tank as your water source? If so, another way to do what you want is to remove the check valve in the City water input and install a standard water hose manual cut off. When on Water pump that valve stays OFF and when on City Water you turn the valve ON. Doug
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
