DrewE
Oct 07, 2018Explorer III
Basically any stove with a regulator you can remove/bypass will work. If the controls and regulator are built into a single doohicky that also attaches to the propane can or cylinder, you're out of luck. I think most multi-burner stoves or grills would be more or less straightforward to convert (depending on how accessible the regulator is, and how it connects to the rest of the unit).
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
