steved28ExplorerApr 08, 2019Low pressure propane outlet - useless?Our new RV has a quick disconnect port for propane accessories. The problem as I see it is, it is after the regulator. I have tried to use it on a couple grills and it seems you cannot put regulated g...Show More
MDKMDKExplorerApr 08, 2019https://www.walmart.com/ip/Camco-Olympian-RV-5500-Stainless-Steel-Gas-Grill/29764622
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
Related ContentPropane pressureTire PressuresUseless Park ReviewsPropane low pressure?high pressure propane regulator
