myredracer
Apr 10, 2019Explorer II
This what I've come up with so far to be able to have 2 propane appliances running at the same time. Not happy with it. It's a big awkward hunk of brass that looks awful when used at the end of the hose. If I use it at the TT end, then I need to run 2 hoses out which doesn't that nice either.
The thing about the propane fittings is that they're RV specific and you get a shutoff valve on the female whether you like it or not which makes it bulkier and heavier.
One problem I've run into is that we use the quick connect fitting on the TT so much it's not working properly and needs replacing.
