WyoTraveler
Dec 25, 2015Explorer
Are you saying that when plugged into shore power that the battery still reads 12 volts? If so maybe your battery is pulling everything down. When plugged into shore power your battery should be over 13 volts. Either the battery is pulling it down or it isn't charging properly. The battery 12 volt problem is not a separate problem. It is all linked.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
