mdecorso
Dec 25, 2015Explorer
I am pretty sure that the battery charging component of my converter isn't working, although I am not sure how or where to test that. I have the cover off and am looking at the cooling fan, etc, but done fully understand everything I am seeing.
As far as I can tell the only way my house battery charges right now is with the vehicle running. I had a problem with that as well and found that the ? Control Switch? that allows power to flow from the auto battery/alternator to the house battery, but not the other way, had failed. Also, the wire from the auto battery to this switch had corrosion and wasn't letting voltage through. Those items are repaired/replaced, but I haven't gotten my battery back up to a full charge yet (charger not working?? ).
Thanks for helping me work through this. I think I am close to answers but need a little more assistance. ....
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
