BFL13
Dec 25, 2015Explorer II
"...10.6 reading when plugged into shore power. Furthur testing at the rv power distribution panel/fuse panel gives me a similar reading when I test from the blue shore power line attached to the 12v panel to the white ground input coming from my house battery..."
The converter (some of them) has a blue (positive) and a white (negative) wire which is the Dc "12v" output to the fuse panel. With shore power plugged in, that should provide the converter with its 120v AC input and the blue and white output should be about 13.6v DC.
The battery also supplies "12v" to that fuse panel and the converter charges the battery going the other way so at the battery posts you should also be seeing 13.6v when shore power is plugged in.
Your converter is not making any "12v" so all you are getting for "12v" is a dying battery doing that.
The converter may not be getting any 120v input even though the rig is plugged in. Or it is but has an internal fault so no 12v output.
On the fuse panel or on the converter itself, look for two 30a DC fuses. If they or one of them is blown, that is one way this can be happening. Those are "reverse polarity" fuses which blow if you hook up the battery backwards. The battery will still run lights ok backwards but the fans will rotate the wrong way.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
