Golden_HVAC
Dec 25, 2015Explorer
Your converter should be supplying 13.2 volts while plugged into shore power.
I think if you solve that problem, then low voltage at the appliances should also be solved at the same time.
What is the exact voltage at your battery?
Do you have a portable battery charger that you can put on the battery to raise it's voltage a bit? Once the battery is full, many portable chargers can put out 15 volts, surely enough to run the water heater.
If nothing else, then try plugging in the RV to a truck, and let it's engine charge the battery for a while. Then all the appliances will run while on the vehicle engine charger.
Good luck,
Fred.
Good luck,
Fred.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
