BFL13
Dec 25, 2015Explorer II
You seem to have a 7300 or an older 6300 converter like the one shown in the photos here:
http://hornerfamily.com/powermax.html
You see the blue and white wires to the fuse panel "lugs" (which have set screws to hold the wires. The blue is from the converter, there is a white from the battery and a white from the converter to the "negative lug" Meanwhile, there is a positive lug with the battery positive (red wire) to the panel too over on the right side lower down . The two 30a fuses to check are just by the blue wire lug
Hard to figure a scenario where the converter is on (hums), but you don't get the 13.6v output at the lugs, assuming the wires are connected ok. (try tightening the lug set screws?)
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
