BFL13
Dec 25, 2015Explorer II
I see you have a 1997 rig, so yours will be a 6300, not a 7300 converter. The 6300 has a somewhat different fuse panel, which is "split" between things that run straight from converter or battery and things which need the battery to act as filter (like the "monitor lights" panel often found in the range hood) for the "dirty" DC 12v power the converter makes. Also it has a battery charging section.
ISTR there is a relay that can be stuck which cuts off the battery charger, and ISTR you can bang on it to get it working again, but Not sure. some folks here know how to troubleshoot those 6300s. I have a 7300, so no help there.
I'll see if they still have a 6300 trouble shooting guide posted.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
