mdecorso's avatar
mdecorso
Low voltage at atwood rv heater, help please
I am getting a low voltage reading at my heater. I am testing it with my voltmeter at the blower motor. I get a 10.6 reading when plugged into shore power. Furthur testing at the rv power distribution panel/fuse panel gives me a similar reading when I test from the blue shore power line attached to the 12v panel to the white ground input coming from my house battery. My house battery is at 12v, a little low I know, but a separate issue. My question is does this mean that my white ground has a bad connection somewhere?
The problem becomes evident when it gets dark and I turn on a couple of lights. They pull enough power away from the heater to slow the blowere and thus drop the sail switch, so no heat. At bedtime, lights go off, heater on, warm time.
  • Okay. I am following the very simple diagnostic there BFL13, and am seeing my converter is bad. Darn.
    I cannot find any fuses on the unit besides the bladed 12v fuses for various circuits and the 120v breakers. Remain hopeful I'll find one after moving a few things to get to the back of the power converter unit and find it is blown.
    The two 30a fuses will be on the fuse panel (front upper left on mine), not on the unit, off by themselves, not part of the collection of 12v circuit fuses. Replace both if only one is blown.
  • Here is a new development. I turned off ALL 12v stuff in the camper. Fridge, every light, water pump, whatever could be on. When I did this I got 16.45v at the blue and white wire on the converter. As soon as ANYTHING was turned on, one light, water pump switch (water was already pressurized so didn't actually run), heater, whatever, only ONE item, voltage dropped to 11.1v. Each successive item would drop it by .1v. So with nothing at all on, I have too much power. With one or more things, not enough.
    Still wondering if this could be a ground issue and maybe I don't need a new converter.
  • From posts a few years ago, there were examples of the 6300 running at up to 21v ISTR. Means it has an internal fault.
  • Almot's avatar
    Almot
    Explorer III
    16.45V alone is the reason to replace the converter.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
