TMBLSN's avatar
TMBLSN
Low Voltage Disconnect
Has anyone put a low voltage disconnect on their battery?
http://www.amazon.com/dp/B00BEA5NPW/ref=dra_a_cs_mr_hn_it_P1400_1000
I'd like to find one that's rated for a much lower amperage and use a relay like this to actually feed the rv:
http://www.amazon.com/dp/B0050I94XG/
It seems like I should be able to get away with less than a 5A (probably 1A) rated disconnect if using a Continuous Duty solenoid. And, thus, a lot less than $60.
Does anyone know where I might be able to find a low-amperage disconnect product?
Thanks.
  • Mandalay Parr wrote:
    Mine is an electro-mechanical solenoid that snaps over and disconnects itself from the battery until you push the button the other way.
    Think it is called a Fat Boy.
    I have a manual disconnect switch. I'm looking for an automatic relay that will shut off the battery if it gets too low (preferably adjustable, probably at ~11.5V).
  • Mine is an electro-mechanical solenoid that snaps over and disconnects itself from the battery until you push the button the other way.
    It's called a latching solenoid.
Having RV issues? Connect with others who have been in your shoes.24,318 PostsLatest Activity: Sep 14, 2025
