Budsmith's avatar
Budsmith
low voltage in receptacle
I had a power strip catch on fire..Nothing was plugged into it but the strip was turned on...lucky I was in the rv when it happened or all would have gone up in flames...It tripped all gfi and a circuit breaker..It also blew out my convertor...Now on the receps at the refrig and convertor shows 41 volts...The fridge went to gas and I am afraid to plug it back up to see if it works on elec...Why do I have 41 volts on those two recept?? Thanks for any replys
  • Old-Biscuit wrote:
    Don't see how a AC circuit tripping due to a short would damage converter
    Does the GFCI reset?
    Did you reset the tripped Circuit Breaker?
    Check that you have 120VAC going to MAIN Power Panel
    Check that you have 120VAC coming from each individual circuit breaker (load side of breakers)
    My bet the converter is on the gfci curcuit and is still not reset correctly
  • Don't see how a AC circuit tripping due to a short would damage converter
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
