SoundGuy wrote:
LRigdon wrote:
Does anyone know why this may be happening? I have a low voltage reading on the converter of 11.92. I removed the converter from the box cleaned. Fan not running.
Voltage went up to 14.25 , re installed converter and voltage slowly going back down to 11.92 and fan still won't run.
Dead battery loading it down? Disconnect it, then you'll know.
X2
To properly test converter DC output it should be isolated from battery
either by disconnecting battery cables at converter terminals or at battery
Also check each battery cell specific gravity with hydrometer
