wa8yxm
Sep 15, 2014Explorer III
Ok, Voltmeters come in two flavors.
One is a TRUE RMS volt meter.. This one does some fairly heavy math (only takes a few very simple parts to do it but its fairly heavy math) to calculate the actual RMS voltage present. I will explain RMS later
The cheaper meter is a PEAK READING meter.
Warning: 40+ years ago when I was in school, the following was part of a COLLEGE course (Electronics, AC Theory) I took. Yes, I aced the course.
Now with a True Sine wave RMS is .707 times Peak, so if the meter sees say
(169 volts (I am rounding here) it displays 120 volts.
BUT with a MSW inverter, due to the "Square wave Like" Or Stile like nature of the wave form,, You will get a lower reading.. Possibly as low as 89 volts (120 * .707)
So: What exactly is RMS (Root Mean Square) Well.... Draw a sine wave (Either true or MSW) on a piece of paper.. Now there are two halves to this wave, A Positive and a Negative half, MIRROR the negative half so it's all positive (Due to the use of the word Square this is not needed but it makes the visual easier)
now, measure the AREA under the the wave line (Between the base line or the ZERO line)
Now, calculate the STRAIGHT DC-Voltage line that would give you the same area.
Because the MSW steps up suddenly, the peak is much lower than on a standard Sine wave, so a non-integrating meter (Peak reading) will give you a false (low) voltage reading.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
