Have 2 new Honda 2K's in a 2013 Jayco White Hawk. Each time the compressor cycles, if they are on econo, the voltage drops low enough to turn off the TV. The hot water heater is on gas. Is this normal...
If trying to run AC off of two Honda eU2000i's then you should not have them on eco. They need to be running at full RPM to keep from sagging. It will also keep just one of the gens from trying to carry the load.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 17, 2026
