Lon-StrExplorerMay 21, 2014Low voltageHave 2 new Honda 2K's in a 2013 Jayco White Hawk. Each time the compressor cycles, if they are on econo, the voltage drops low enough to turn off the TV. The hot water heater is on gas. Is this normal...Show More
2oldmanExplorer IIMay 21, 2014Unfortunately either or both of the above solutions will have to be done. I guess I'm lucky my gens will run my air on Eco.I used to have my inverter wired in such a way as to kick it off until the gens could catch up.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
Related ContentLow Battery VoltageLow Shore VoltageLow Voltage[SOLVED] Bad converter? Low voltagelow voltage in receptacle
