Have 2 new Honda 2K's in a 2013 Jayco White Hawk. Each time the compressor cycles, if they are on econo, the voltage drops low enough to turn off the TV. The hot water heater is on gas. Is this normal...
You don't run ECO mode when you have a full power application sucking every last amp out of the system to overcome the equivalent of 60 amps or "rotor lockup" amps on the compressor on an AC unit.
Put at least one of your generators in regular mode when starting up the AC, perferably both, and make sure both motors/generators are thoroughly warmed up for a couple of minutes, before turning on the AC unit.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
