mabellExplorerApr 13, 2015Low VoltageWas reading in the RV the other night (that's another story) when the lights dimmed then came back bright. Did the same later. Today I turned on the main lights (10 bulbs) and they seemed dim. I turne...Show More
mabellExplorerApr 13, 2015Thanks Wolfe10. But sealed batteries. I'll charge until morning, let it sit a couple of hours and check voltage. Should I disconnect after charging?
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
Related ContentLow Battery VoltageLow Shore Voltage[SOLVED] Bad converter? Low voltagelow voltage in receptacleLow Voltage - Heat Wave
