mabellExplorerApr 13, 2015Low VoltageWas reading in the RV the other night (that's another story) when the lights dimmed then came back bright. Did the same later. Today I turned on the main lights (10 bulbs) and they seemed dim. I turne...Show More
MEXICOWANDERERExplorerApr 13, 2015Measure voltage at the batteryThenMeasure voltage at the ATO fuse panelThenMeasure voltage at the light switch terminalsThenMeasure voltage at the light socketThen come back and report your readings.This is how the proessional technicians do it.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related ContentLow Battery VoltageLow Shore Voltage[SOLVED] Bad converter? Low voltagelow voltage in receptacleLow Voltage - Heat Wave
