Old-Biscuit
May 17, 2016Explorer III
jerseyjim wrote:
When new (2001)my Atwood seemed way too hot, so I got the previously mentioned "manual" adjustable thermostat. Worked fine for quite a few years...but even tho it is still on there, I guess it doesn't work anymore. Also...when it did work, it only seemed to control when on propane.
So...I now use a bit more cold water in the mix. No biggie.
That would be due to the fact your 2001 model has 'separate' t-stats for electric and propane
Propane is in outside compartment
Electric is on backside of water heater tank by the electric element
2004 Atwood changed designs and since then ALL use one set for propane/electric ----------prior to that design change separate controls
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
