DrewE
May 18, 2016Explorer III
fourthclassC wrote:
Thank you for all the replies. I understand that hotter water will require mixing more cold and the hot will last longer. My concern is damaging the plastic piping.
I will invest in the adjustable thermostat or the lower temp. (120 disc)
If it's PEX tubing, it's fine for quite high temperatures. From this page, it's rated for use at up to 100 psi at 180 degrees or 80 psi at 200 degrees.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
