markm's avatar
markm
LP fuel Onan 5.5kw generator
Considering an Onan 5.5kw generator on the next trailer. It will run off LP. Main use would be for power when stopping overnight at rest areas or parking lots. Also, charging batteries during generator hours when camped at national parks.
Relevant specs for the unit:
wt. - 288 lbs
LP usage:
.4 gals/hr at idle/ no load
.7 gals/hr at half load
1.1 gals/hr at full load
30 lb propane tank holds 7.5 gallons of propane.
At idle, one tank would last 18.75 hrs
Half load, one tank would last 10.7 hrs
Full load, one tank would last 6.8 hrs
For those who have this generator using LP as the fuel:
How do you manage your generator usage for the LP available on the trailer?
Do you carry extra 30 or 40 lb tanks in the truck?
Carry extra tanks or a larger tank on the trailer?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
