groundhogy's avatar
groundhogy
LP gas Regulator... better brands?
So one thing I can’t understand. I have a rental townhouse that I’ve had since the 80’s.
It has natural gas service. I guess there is a gas regulator on it, but I wouldn’t know...CAUSE ITS NEVER EVER BEEN A PROBLEM IN THIRTY YEARS !
Then how come i am now preparing to change out my two tank regulator for the second time in four years?
I did the percussive tuning thing before. I tried whacking it again and no dice this time.
It’s a Camco model.
Is there a better brand choice?
Thanks
groundhogy
  • Oil in the propane is a supply issue. Need to fill somewhere else after you replace the equipment.
  • If I have to do this job yet again..
    I would like to install a quality piece of ... hardware.
    Things break around here so fast, I don’t like to do the same fix over and over. I can’t keep up. Lol
  • Well, this happened before.
    At that time, I blew air from the oven/range connection to the tank area. I had the connection at the tank open. A bit of oil came out but otherwise clear.
    Troubleshooted it down to the regulator.
    Got pissed and smacked the **** out of the regulator and it decided to start working again.
  • can you disconnect a pigtail and determine if gas flows though it?
  • jdc1's avatar
    jdc1
    Explorer II
    The one that goes from my 250 gallon propane tank to my house is 30 years old. Hmmmmm
Having RV issues? Connect with others who have been in your shoes.24,225 PostsLatest Activity: Mar 31, 2025
