Johnny_HurryupExplorerAug 25, 2019LP generatorsRoughly, how much propane does an LP generator use in say, a 12 hr period? I'm thinking of buying a Class C with the 6 cyl diesel and some of those coaches only carry 12 gal propane tanks,
PNW_SteveExplorerAug 25, 2019About 15% more than a similar gasoline generator would use under the same load. Seriously, You have not given nearly enough information to be able to give you a meaningful answer. What size generator?Inverter or fixed speed? What loads are you supporting?
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
Related Contentonan 2500 lp generatorGenerator noise reductionGenerator operationDiesel or LP generatorLP Generator Starts then Stalls
