Oasisbob's avatar
Oasisbob
LP TANK DATE STAMP ?
From date of LP tank mfg, how much time until the tank can not be refilled before being recertified? My DW did a tank exchange and I just realized the mfg, date is 01-07 on the exchange tank which I now need to fill. I can do another tank exchange but hate to. Anyone remember?
  • Requalification
    (USA) NFPA deginitions
    ASME Container (or Tank). A container constructed in
    accordance with the ASME Code.
    Container. Any vessel, including cylinders, tanks, portable
    tanks, and cargo tanks, used for the transporting or storing of
    LP-Gases.
    Cylinder. A container constructed in accordance with U.S.
    Department of Transportation specifications (Title 49, Code of
    Federal Regulations).
    2-2 Containers.
    2-2.1.3* Containers shall be designed, fabricated, tested, and
    marked (or stamped) in accordance with the regulations of
    the U.S. Department of Transportation (DOT), the ASME
    Boiler and Pressure Vessel Code, "Rules for the Construction of
    Unfired Pressure Vessels," Section VIII, or the API-ASME Code
    for Unfired Pressure Vessels for Petroleum Liquids and Gases, whichever
    is applicable at the date of manufacture. (See Appendixes C
    and D.)
    2-2.1.5 Cylinders subject to the jurisdiction of DOT regulations
    shall be filled, continued in service, and transported in
    accordance with those regulations.
    Cylinders that are built to DOT standards may be filled for 12
    years from the date of manufacturer and then be subject to
    requalification. NFPA 58 5.2.2
    Requalification Method
    Visual (per NFPA 5.2.3) 5 years
    Modified Hydrostatic Test 7 years
    Water-jacket Hydrostatic Test 12 years
  • I was getting a 20# filled and the guy said that he would fill it this time but not again.
    Getting home I looked at it and it looked like a food grill had spilled grease on the top edge. I figured that I would sand the rust off and paint it.
    When I sanded it I found that it was badly pitted.
    I guess that the guy knew what he was what he was doing, thanks.
  • is that is the regular gas grill size type just take to a tank exchange places and pick one with a newer date. easy enough way to exchange the old for new.
  • A few years ago I had some Canadian friends that just took some metal stamps and re-stamped their own tanks to a more current date...Nothing I would do, but just sayin
    B.O.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
