jorazExplorerJun 06, 2016LP vs. GasI'm thinking about buying another rig (sold ours six months ago). This rig is a GMC (1976) with an Olds 455. It's low mileage and has only run on LP. I've got a couple of questions: 1. Other than i...Show More
time2rollNomadJun 07, 2016LP is not less efficient as much as LP just has lower energy per gallon vs. gasoline.If you expect to use only LP that is fine but if you expect the gasoline system to work you had better give that a test drive.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
Related ContentDiesel vs gas......................Lp gasLP vs Gas vs Diesel GeneratorLP gas leakFord 6.2 gas vs 7.3 gas highway gas milage
