I'm thinking about buying another rig (sold ours six months ago). This rig is a GMC (1976) with an Olds 455. It's low mileage and has only run on LP. I've got a couple of questions: 1. Other than i...
I was an oilfield hand, retired Petroleum Engineer, and the biggest problem was that cooling in gasoline engines depends on vaporizing the gasoline. The heat absorbed really adds up. So a converted engine needs extra heat removal, to run on nat. gas or LPG, plus special alloys in the valves and seats.
So your question is, was the work done right? Otherwise run it on gasoline.
Converted Kubota diesels worked good for us, Honda gas engines not so much.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
