Looking @ replacing reading lights over bed, now has 11391F bulbs in them, will there be enough light to read by if I install 5050168 LED bulbs rated @ 160 Lummins. Thanks in advance.
Took a while to figure out your numbers... a 11391F is the same as a 1156 base. Your 5050168 LED is a over priced tail light bulb. 168 lumens is going to be borderline if it is not focused. When I search Ebay for 1156 led I get 20,000 hits. If the light fixture is in the right position, a spot light like this may be the answer. While something like this may be too much lite, it gives you a better idea what's available for $3.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
