Itchey_Feet
Oct 23, 2015Explorer
Lummins ?
Looking @ replacing reading lights over bed, now has 11391F bulbs in them, will there be enough light to read by if I install 5050168 LED bulbs rated @ 160 Lummins. Thanks in advance.
fluffo2 wrote:Those would work well for a bayonet socket. I'm planning on replacing the florescent tubes in a couple of fixtures so I would need a different solution. I most likely will attach them to the fixture and solder wires directly to the pins.
Tom, you may want to try these. 100% of the light can be directed through the lens.
http://www.ebay.com/itm/BA15S-to-G4-GU4-GU5-3-Low-Voltage-Adapter-for-LED-Pack-of-5-/151412491792?hash=item2340e34610:g:vhAAAOSwDk5UF9o4
