Itchey_Feet's avatar
Itchey_Feet
Lummins ?
Looking @ replacing reading lights over bed, now has 11391F bulbs in them, will there be enough light to read by if I install 5050168 LED bulbs rated @ 160 Lummins. Thanks in advance.
  • If you have the ability to put in a pair of light bulbs, it might be plenty of light.
    For my bathroom, I took out the socket that holds the old lamp, and wired in two panels in each side of my twin pack light fixture. The panels that I used are 24 LED 5050 LED lights, with 4 of them on, I have more light than before, and it only draws 0.4 amps at 12 volts.
    Good luck,
    Fred.
  • Considering the location 160 lumens should be enough, although you probably will notice that it's a bit less bright than the incandescent.
  • A 60w incandescent produces about 800 lumens. You will have to decide if it works for you.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
