RJsfishin's avatar
RJsfishin
M-4 Plugs, or Chop'm Off
I've got 2 panels mounted, even made'm tiltable. And I got a 10ga twin lead down the fridge vent.
Now I'm lookin at the M-4 plugs layin all over. What makes me want to chop'm off, and mount a couple watertite junction boxes ? Is that the way to go ?
Do the boxes have screw terminals inside them, or solder everything ?
2nd, I still have to make my tilt arms.....how long, or what degree for winter in Qzs AZ ?
Thanks
  • West,
    Thanks for your ideas and comments,....gave it all some serious thought before "cheating":)
    Actually I connected only 1 panel to that 10ga twin lead.
    Today I'll run a 2nd twin lead for the 2nd panel, only for trouble shooting the panels separately down below.. A box above would have allowed separation above. But I have lots of 10ga twinlead, 100' roll.
    I'm cheating on the tilt rods too, making them longer than maybe necessary, w/ a couple xtra holes,...cut them off in AZ when I get the sun square w/ the panel ??? :)
    westend wrote:
    RJsfishin wrote:
    Made easy work of the wiring, chopped off the MC-4s, and soldered them all together. Then liquid taped the soldered connection. Another coat or 2 will have the connection completely waterproof. Then a blob of Dicor over the connection, anchoring it all to the roof. I see no need for boxes
    Cheater :B
    Just kidding, of course, do whatever works for 'ya.
    Cheater :B
  • Made easy work of the wiring, chopped off the MC-4s, and soldered them all together. Then liquid taped the soldered connection. Another coat or 2 will have the connection completely waterproof. Then a blob of Dicor over the connection, anchoring it all to the roof. I see no need for boxes
  • Rich,
    I made my own combiner box using a plastic weatherproof box and two lug strips I salvaged out of a load center. I glued/screwed the lug strips into the plastic box and used a waterproof box entry fitting for the MC4 entry cables. I have the wires leaving the box towards the controller in plastic pipe so didn't need another box entry fitting.
    If you look at the prices for these off-the-shelf combiner boxes, you'll realize you're in the wrong business.
    All about tilting
    FWIW, I found my optimum tilt angle for my location in the Winter and made the tilt struts to tilt at that angle. I leave the panel at that angle as it doesn't give up much harvest, seasonally, and will shed snow/rain/hail/dirt easily.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
