RichertExplorerJan 08, 2022macerator pumpsnot sure what forum to post this in--- does anyone recommend a macerator pump? How far can you pump the waste? what is minimum size discharge hose can you use? I need to get waste about 125 feet to ...Show More
toedtoesExplorer IIIJan 08, 2022I run my about 35ft with lots of turns with no problem.I run it off the RV battery, but have the RV plugged into shore power so it gets a little extra oomph.I only use it at home as dumpstations are just a short straight dump.I have the portable one and since my battery is on the other side of the RV, I use a heavy duty jumper cable run under the RV to connect it.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
